Sewing Machines Logo
A
Anonymous Posted on Jan 07, 2014
Feed dog adjustment - Husqvarna Husky 165
How do you adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine?
To adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine, you can follow these steps:
  1. Turn off the sewing machine and unplug it from the power source for safety.
  2. Remove the needle and presser foot from the machine.
  3. Locate the feed dog adjustment screw, which is usually located on the backside of the sewing machine, near the feed dogs.
  4. Use a screwdriver to loosen the feed dog adjustment screw. It might be a slotted screw or a thumbscrew, depending on the model.
  5. Gradually adjust the height of the feed dogs by turning the adjustment screw clockwise or counterclockwise. Clockwise rotation raises the feed dogs, while counterclockwise rotation lowers them. Make small adjustments and test with a scrap fabric after each turn to achieve the desired height.
  6. Once you have set the feed dog height, tighten the adjustment screw securely.
  7. Reinstall the needle and presser foot, and plug in the sewing machine.
  8. Test the machine with a piece of fabric to ensure the feed dogs are working properly and at the desired height.
It is important to consult the sewing machine manual for specific instructions related to your model, as the location of the adjustment screw may vary.
2answers
Fabric not advancing
Make sure the feed dogs are not in the dropped position (for darning).
If it is very light-weight fabric, most machines will have a presser foot pressure adjustment that will increase the presser foot's pressure on the feed dogs, thus pulling the fabric through better.
Make sure the feed dogs are clean--no debris stuck between the teeth, under the feed dogs, or around the bobbin case. If it is an older machine that has been used a lot, the feed dogs could be worn down and need replacement or adjustment. (Do not run the machine with the presser foot directly on the feed dogs. This will cause excessive wear to the feed dogs and the presser foot.)
My fabric won't feed
Check that the feed dogs have not been dropped for darning or free motion quilting. If the feed dogs do not rise above the needleplate, they will not pull the fabric through the machine.
Feed dogs do wear (which is why one should always sew with fabric against the feed dogs--never on bare metal).
Something else that happens is that gunk builds up between the teeth of the feed dogs so that they no longer have the grip they need to move the fabric.
Another thing to check is the presser foot "pressure." A lot of sewing machines have a pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and feed dogs. (Consult your owners manual.) he pressure can be adjusted according to the type of fabric being sewn.
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
sewing patternreview com
2answers
Feed dogs are hitting the needle plate
Needle is bent replace with new needle. You may need to adjust feed speed so that needle doesn't bend. Good luck
Adjust dog feed
The feed dogs in all Classic Bernina machines from the 130-180\'s will eventually come out of adjustment. This is due to the so-called cost savings modern manufacturing method of drilling holes in the machine frame parts and using thread forming screws instead of tapping or cutting cylindrical threads and the use of standard fasteners.
Regarding the screw fastener itself having a cylindrical screw form, the Bernina Classic machines used thread forming screws. Not necessarily a bad thing but in this case a dumb idea. Because these screws are not exactly cylindrical, they will not hold tight over time, hence loosening of the feed dog\'s height adjustment. You will need a T-10 Torx screw driver to make the adjustment.
Proceed by opening the bobbin cover door. You will find a rectangular opening to your upper right and will be able to see the screw head of the feed dog adjustment. With the feed dog in the upper most raised position, loosen the screw and lift the feed dog. Tighten the screw.
Check the height of the feed dog by rotating the hand-wheel in the direction of motion until the needle eye is flush with the needle plate. The feed dog teeth will also be flush in the normal position. If too high or too low, readjust to this height and, voila\'..... SewTechnical Home
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
2helpful
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
4helpful
3answers
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
7helpful
5answers
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 • Singer 2662
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
