Dell Inspiron 1525 Notebook Logo
Anonymous Posted on May 24, 2009
No internal hard disk found
I have a dell 1525 laptop. when i buy it. it contains two hard disk partioned. one is 220gb and 2nd is 10 gb. now i want to create partion of it. when i want to partion it. it says during booting no internal hard disk found. and i am unable to partioned it............... yes when i go to format my system with f12 with the windows vista cd. it shows hard disk. but i cant partioned. and xp cant support.........
  • Anonymous May 11, 2010
    If you are trying to partition the 10gb maybe it is where the restore files is residing if this unit have a feature of restoring using restore disc.
  • Lewis Fulkerson
    Lewis Fulkerson May 11, 2010
    Are you trying to partition from within Vista, or by booting for 3rd party software? Also, being a laptop, it is most like one single drive that has already be partitioned into the two drives you describe.
Lee Hodgson
Level 3:
  • Dell Master 4,810 Answers
  • Posted on May 24, 2009
Lee Hodgson
Dell Master
Level 3:
Answers
4810
Questions
Helped
1783013
Points
15941
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
Ginko
Level 3:
  • Dell Master 19,396 Answers
Ginko
Dell Master
Level 3:
Answers
19396
Questions
25
Helped
8078174
Points
55462
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
2answers
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
I have a two-year old Dell Inspiron 1525 laptop. for no apparent reason, it will now not boot up. When I turn it on, I get the following message......"Internal hard disk not found. To resolve this...
The hard drive may have failed or a virus has corrupted the Cmos data.
Try entering the BIOS and checking that the Cmos recognises that the hard drive is there. If it doesn't, remove the hard drive and re fit it, booting up again.
3helpful
Says internal hard disk drive not found, to resolve this issue, try to reseat the drive
The hard disk has died, you will have to replace it with a new one then reinstall Windows using the recovery disk.
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
1helpful
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
No internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
1helpful
Formating the hard disk partition
Hi
install ur o/s cd
then select or allocate
partion
Thanks
1helpful
Reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Installing of RHEL 4 in dell inspiron 1525
load the linux driver for sata controller
and update the BIOS.
verify and configure the hardware setting in BIOS that works for linux
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
