Kenmore 64802 Top Freezer Refrigerator Logo
A
Anonymous Posted on Jan 06, 2014
Water from behind control panel
There is a buildup of water coming from a vent behind the control panel
1 Related Answer
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Aug 31, 2009
SOURCE: Water leak from Styrofoam insert of Kenmore 79202
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
1helpful
2answers
Ice maker not hooked up. left half only freezer incl back panel has moderate to heavy ice buildup & frost. vents clear.
most likely the defrost sensor as they are more likely to fail rather than the defrost element. either way if you are going to remove the back panel take youe time and be careful not to damage the Styrofoam attached to the back of the panel cover. A hair drier will help melt the ice, when the panel come freepull it out far enough to look behind it for any wire connectors and disconnect them, now the panel can be removed. remove any ice remaining in the compartment using a hairdryer or by spraying hot water. make sure the drain tube is clear of ice and debris, if you have a turkey baster you can use it to squirt hot water down the drain tube. if you need help let me know i am a service technition in the Sonora area
There is dust buildup behind the control panel due to the openings in the vent trim. I'm worried the dust may eventually cause a short, etc. in the electronics. What is the best way to clean this ar
Use a small rubber hose or flexible tube and place one end near or on the dust. Blow thru the other end. The dust might have some grease in it, use toothbrush or small long bristle brush, similar to a baby bottle brush but much thinner, to help loosen dust.
Do not add insulation!!
If it's a convection oven, the vent might be intake. Most vents are exhaust. Does heat come out of it during use?
Is it fan induced? Put a piece of paper near it, does the paper get sucked in or blow outward?
How do i remove the gas control valve hermostat
do you mean the pressure relief valve on the front? if s it will turn. it is just has caalcium buildup. if you mean a water valve behind the water heater. it will come off. it is probably just a PEX fitting. you will have to replace it. home depot has all the fittings
1helpful
Ice buildup under bottom drawer in fridge, leads upward on left side to a vent...and the freezer also gets an ice build up coming from the icemaker. also icecream popsicles etc are not staying frozen. any...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
2helpful
1999 subaru legacy vent is stuck on defrost
This sounds like the control panel. 90% of the time something gets spilled on the control panel from the cup holders right above, The buttons get gummed up and no longer push the switches behind the button. remove the control panel and dissassemble it, soak the non electronic parts in hot water with light soap, problem solved, My 98 Outback had the same problem.
3helpful
Water drips from under door. the water is
There is a ventilator mechanism on the top right corner, behind the control panel / front cover.
******TURN THE POWER OFF AT THE BREAKER BEFORE STARTING, BE SURE POWER IS OFF ******
Open the door; remove all of the screws that hold just the front panel (not the controls panel). These screws are located on the inside of the door, around the outer edges. The front door panel will be able to be removed. Close the door with the front panel removed.
***IMPORTANT be sure nobody will come in contact with the exposed wiring (especially little kids) *********
Turn back on the breaker, turn on the washer, and run a quick rinse cycle. See where the water is coming from.
On my washer (same model) i had to replace the entire vent kit (sears parts ~$40.00) Call them with your model and serial number, or search online. Removal and replacement was very easy, and it did fix my leaking problem. Checked with the front door panel off and a quick rinse before I TURNED POWER BACK OFF and put the front cover back on.
Root cause?? From what I can tell, the solenoid stopper hardens over time, which allows for water from the spray arms to leak past.
Get it fixed now before you smoke the motor or control card. My part number was ABT35083501 be sure to double check model before purchasing.
Freezer has stopped working in refrigferator
Check for a frost buildup on the rear freezer panel. You may then have to remove all contents and removethat rear cover to inspect the cooling coils behind the cover. You may find a solid sheet of ice behind the panel meaning: the defrost heater, timer, or relay has failed.
2helpful
2answers
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
