Televison & Video Logo
A
Anonymous Posted on Jan 05, 2014
Ht-q100 program with ht-dm150 remote control - Universal Remote Control Activity Based Universal Learning Remote Control
1 Related Answer
ANTHONYPAULB
ANTHONYPAULB
  • 17 Answers
  • Posted on Nov 30, 2007
SOURCE: Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
tip
Remove Regionalisation
Hi All
After having my HT-Q100 repaired by an official Samsung repair centre, I was unable to play any DVD's - even UK ones!
So I phoned Samsung, they said I should return it to the repair centre for it to be fixed.
I couldn't be bothered to waste time on this yet again, so I logged onto Moneysavingexpert.com and found that you can remove regionalisation on DVD players and it's totally legal!
Therefore the following instructions are for removing the regionalisation on the Samsung HT-Q100 so you can play any DVD's! I've just carried this out and it's fixed the DVD problem and can once again play DVD's!
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
The above was courtesy of the link at: http://www.videohelp.com/dvdhacks/samsung-ht-q100/7502
Qubix
HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
3answers
Cant use dvd player, the word lock keeps coming up, dont know how to remove it, the model is a samsung digital home theater system HT-DM150
i have a samsung dvd theater system ht dm150 it will sometimes read the dvds dut majority of the time it wont read any dvd i even used a cd cleaner on it. 80% of the time it will play music cds.
I can't program my home theater to my universal remote
logitech remote will be only one to control it best to use orginal remote with it has all nice fetures in audio ect
Samsung ht q100
No it does not. It will upscale regular DVD's to HD resolution, but that's an electronic trick. You'll need to buy a BluRay player to watch high definition discs.
The HD-DVD standard has been abandoned by Toshiba, so the Sony players are the one's to look for.
2helpful
2answers
Hope this helps..
6answers
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
