I have had the same problem when I went to redo my Windows Vista Machine. The answer is simple. Install the software from the installation disc that came with your printer. Next go to lexmark.com and download the driver package for your printer and install that. Now a window should pop up asking you if you want to install over the original or make a copy, MAKE A COPY.. After installation is done open lexmark studio and pick to open the copy version and there you go, you can now use your lexmark studio, and for some reason after you open the program once like this the original one works!!!!!!!!
I've faced the same problem, Imaging Studio and the other supporting applications need at least Dotnet FX 2.0 to be installed. What I did is to uninstall X2500 drivers and all the previous installation of the Lexmarks applications on the CD driver, then I've Dotnet and at the end I've reinstalled drivers and support applications (Imaging Studio too) and now all works perfectly!
I have tryed to down laod the hardedrive but an erro 23win did not re spond or it will not late me down load it . the computer is not committeing with the printer
I downloaded the new ad-aware 2007 (I already had ad-aware-se) and ran a full scan and it caught something when it scanned lexmark.
When I went to run lexmark again it worked fine. Hope it works for yall as easy as it did for me.
Unload the programme from your computer. Clean the Lexmark Disc.Insert the disc again. It worked for Me. Best of Luck. Kirkie.
We have a friend that is having the same problem. Have you guys tried going to the lexmark site to download windows vista updated drivers? I am going to ask him the same question. If not, possibly going to: http://support.lexmark.com/static/229-1-0-590.html
and downloading the most current drivers.. it might fix the problem since it IS a compatibility problem with Windows Vista.
SOURCE: lexmark x2500 imaging studio App4R.exe not working
Your best option at this point will be to uninstall the Lexmark Software and reinstall it using the CD. If you do not have the CD available then you can go to Lexmark.com, go to Downloads then select your printer model and then go to available downloads there you will be able to find the newest driver along with the imaging studio.
I can not open my Lexmark File. Keep getting App4r.exe on screen.Can you help ? Kirkie
I have the same prob.
Same problem! I uninstalled and reinstalled and still the Imaging Studio will not open. Emailed Lexmark support and all I got was reply on how to install the Lexmark Imaging Studio, not how to fix the problem showing error in app4r.exe. I KNOW how to install, but somewhere along the way my D: drive quit working, doesn't even play a music CD anymore. Browsed for answers and found something that said something about needing the Microsoft.net 2.0 framework to run the Lexmark program. Installed that and still the Imaging Studio won't open. I can print things using other programs, but liked the Imaging Studio because (at first) it would print multiple photos of different pictures on one page.
Does anyone know how to fix the Lexmark Imaging Studio program so it will open and be usable again??
i want to make my scan color not lighter but I CANT BECAUSE IT SAYS I HAVE THE APPR.EXE
my problem is the same as josh1998's, windows has stopped working will notify you when a solution is offered.
I uploaded my printer to my new computer and now the imaging studio is not working and i can not use the scanner...please help! I have reinstalled the software and checked all the wires and connections, and still is not working, i have no icon for it now and nothing in my programs for the imaging studio.
i'm using the old software that was compatable with other windows (i'm now using vista). often i can't get the imaging studio to boot. i've checked with windows, and they don't seem to have an answer to my problem. any help?
the problem is that windows is craprap it allows liberies in other older operating systems(XP), the nerds try hard, but still cant get laid...
I have the same exact problem as Josh. Lexmark x2500 will not allow me to scan pictures or even open the imaging studio icon without the error message: app.4R.exe has stopped working, etc...I have had no luck in fixing this problem over the last year and a half.
