I replaced the spark plugs on my 1997 mitsubishi montero sport ls 4wd 3.0 v6. After i placed everything back and check for any loose connection i started the montero, but it turns out that it reved up itself to about 3k rpms, i shut it down and started it again by this time checking everything, but when i disconnected the mass air flow sensor box, the montero when to normal idle, if i plug it back it revs up to bout 2k rpm, could it be that the box went bad or i need to reset the ecm bythe method of disconecting the battery for 20 min like some other members advised? Ny help is greatly appreciated, thanks
Start by checking for a lose vacuum line that is what it sounds like to me u may have pulled one lose and not have seen that u did
Testimonial: "I sure did, i traced my steps back and make sure everything was pluged back, theres two small diameters hoses and the two that goes to the head valve covers, but what throws me off is the plug to the m-a-f-s, it revs up if i connect it"
