type msconfig in field at bottom of box that just opened
hit enter
click on the "start up tab"
uncheck all boxes
click apply
click save
press ok to reboot
reboot computer
click "ok" for pop message.
Still hour glass?
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Repair the notebook operating system, Some of the file on system might be missing. Try to send the error code which was written on the blue screen. I think this will make the question simple.
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
This should help. When the hourglass symbol stays on, press and hold down the start button for at least 15 seconds. The screen should clear and then you can navigate back to the correct opening screen and select music, videos, photos etc. as you require.
same thing to me but not off ebay when i first bought my 7100t all it would do was show an hourglass but i never used it for a month then i charged it then it worked fine
Try and plug it in your computer once again and see if the hour glass budges. Then safely remove it by clicking the "Safely Remove Device" Icon on your PC tray (where the clock is on a PC)...
If not, theres probably a software reset hole at the back or sides of your mp4 player, try pushing it with a toothpick or similar pointed thing.
