j
jeffrey sison Posted on Dec 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 2100012C I CAN NOT RESET MY PRINTER BECAUSE OF THE ERROR 2100012C
Martin Smallridge
Level 3:
  • Epson Master 419 Answers
  • Posted on Dec 21, 2013
Martin Smallridge
Epson Master
Level 3:
Answers
419
Questions
0
Helped
289788
Points
1120
This article deals with the various Communication Error issues when attempting to reset an Epson waste counter using an AdjProg service utility, which I'm pretty sure you're trying to do:
http://www.octoink.co.uk/kb/questions/119/
Communication error error code :2100012c - Epson Stylus Pro 10000 InkJet Printer
1) If you are trying to use an Epson Adjustment Utility on the system, the issue occurs. Check if the printer is connected to the system via a USB cable, properly.
2) The utility may not work over a network connection. If you have a system with Windows Vista or 7 operating system, it does not work.
3) Check if the utility is working in the compatibility mode. If you wish to connect many printers to the system, resetting the utility may help to resolve the issue.
4) If the USB connection is only to a single printer, turn on the printer and the system.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
36helpful
2answers
Communication error error code :2100012c how to fix
4helpful
Epson stylus t30 error code 2100012c
This error is usually shown when using the AdjProg to try to reset the waste ink counter.
The error code is caused by one of the following:
1. More than one Epson printer is connected (turn any others off)
2. The utility can't connect using the "Auto" setting for the printer "port" (Select the specific printer port using the "Select" button).
This issue is covered with other AdjProg errors in this article
3answers
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
1helpful
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
17helpful
Canon error p08 Problem
Follow the instructions step by step
1. Turn off printer, cable power still plug in,
2. Press Stop/Reset button don't release
3. Press Power Button don't release and than release Stop/Reset button
4. Press Stop/Reset button 2X , wait until service mode to " 0 "
5. Turn off printer, cable power still plug in
6. Press Stop/Reset button don't release
7. Press Power Button don't release and than release Stop/Reset button
8. Press Stop/Reset button 4X , wait until service mode to " 1 "
9. Turn off printer, and loose cable power, wait one minute.
10. Connect cable power, turn on printer again, now this printer ready to use.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
13helpful
2answers
Printer is displaying error po8
The Canon Pixma MP250 error p08 code means your printer has wasted ink. You will need to reset the printer by pressing the reset button and holding it and then press the reset button twice to enter the maintenance mode to reset the wasted pad ink. Press the reset button four times and then turn the printer button off and then back on.
2helpful
3answers
I have 2 epson workforce 1100 there is error of mentenes tank i resive some resetter program but when i try it i resive cominication error eror code :2100012c how i can fixit
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
