I tried old & new SD ranging from 4 to 16 gb. The IR light will now come on either
SOURCE: PANASONIC DMR-ES35V CANNOT READ ANY
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
SOURCE: LG Fusic 550 Sprint - Memory Card Error with 8 GB Sandisk MicroSD
Believe it or not, a lot of the older phones (an even the newer phones) will not support the 8GB memory card. Most of the phones on the market that support 8GB cards are the smart phones and PDA's. There are a few standard phones that support it but not many. Unfortunately, the LG 550 is not one of them. :o/
You may need to take it back and exchange it for a smaller one.
~*~ Your Rating is Greatly Appreciated *~*
SOURCE: Micro sd card not showing up on the gps
Have you got GB Discoverer on the card? The map should appear on the Map Information list in the Setup > Map area. Double check the placement of the map card. Also, in case you have not found it yet, there's wealth of information on the Oregon Wiki here: garminoregon.wikispaces.com
SOURCE: ''no memory card'' error on canon sd 1000 camera
Make sure you always turn off camera before inserting or removing SD cards.
Try reformatting the card using the camera settings. Doesn't work? Try reformatting the card on your computer assuming you have card reader in it. Doesn't work? Try using the card in another devise. Works? Cameras in trouble. Doesn't work. Bad or corrupted card.
Lastly make sure you set the camera to use the card and not the internal memory.
SOURCE: tried to format sd card screen reads filesys error
E-mail your question to this address:
http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
