20 Most Recent
Toshiba SD-2800 DVD Player Questions & Answers
Inadvertently plugged in device to a 220 outlet verus a 110.
Hi...
I'm not sure about this model but most have a "universal switcher" power supply inside that works up to 220 volts.
Also ( with NO power connected ) take the cover off and check for a glass fuse ( 20mm long) . See if that has blown . Radio Shack has plenty of fuses
I have an old DVD player from 2002 & I'm
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Our dvd player now only works showing movies in
someone must have pressed something mistakenly.
Check the DVD remote and press PAL/NTSC. The color should appear.
Or you could also check the video wire at the back of the DVD and TV, maybe it has loosed contact.
I wish you all the best.
My player works but i cant get sound
check if muted on settings, try rock the earphone jack...for hardware problem, a two pcs transistor serves as switch for the mute was leaky need to replace,
Toshiba Sd2800
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
