SOURCE: Phone beeping!
on some phones the beep refers to a voice mail message that has been left on your answerphone which will be left at the BT server, you can dial 1571 to retrieve the message. Other than that if you have re registered the phone correctly following the instructions on page 22 of the below manual, return the set as faulty. http://media.venda.com/btshop/ebiz/btshop/invt/cay222/freestyle2200.pdf
SOURCE: Uniden TRU8885 Register/Deregister Issue
Here's what you do:
Should work like a charm.
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
SOURCE: How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
SOURCE: DeRegistering a Damaged Cordless Phone???!!!!
Here is the procedure as given to me by Panasonic Tech Support.
To DEREGISTER, using the handset you want to register, push MENU.....002.......335...and hit ok.
Then press the handset number you want to deregister (1 through 4). Don't worry if the handset says there is no link to base. This is because you just unregistered it so there will be no link.
To REGISTER, press and hold the locator button on the base unit until the green LED starts blinking. Then take the handset unit and press MENU.......001 and hit ok. Your unit should now be registered.
