20 Most Recent Uniden TCX905 Cordless Accessory Handset and Charger Phone Questions & Answers
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Uniden TCX905... | Answered on Oct 16, 2015
We thank you for being a loyal customer. Please note this model has been discontinued for more than 2 years and unfortunately, troubleshooting and/or parts are no longer available. We apologize for any inconvenience this may cause you.
Uniden TCX905... | Answered on Jun 30, 2015
push mute button again
Uniden TCX905... | Answered on Jun 28, 2015
Do you actually have two lines to the room? Check to make sure all phone cords have four contacts.
Uniden TCX905... | Answered on Nov 29, 2013
First, select Deregister HS from the main menu. Secondly, press the red phone button and the # key simultaneously for about 5 seconds to finish deregistration. You will then see a message telling you to place the phone in the cradle of the base unit to register it to your unit. An "operation complete" message will confirm that the handset is now registered and ready to use. Good luck.
Uniden TCX905... | Answered on Jan 17, 2011
Not sure about the refurbish issue...but have you tried to de-register the handset by holding down the end key and the # key, then placing on the main base unit to register with your system.
Uniden TCX905... | Answered on Sep 03, 2010
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Uniden TCX905... | Answered on Jul 15, 2010
I don't have the answer but have the same problem. Uniden tech support had me disconnect power, etc. to no avail. Next solution was "replace the unit". I'm looking for a two-line phone with no answering device - use voice mail. Any ideas?
Uniden TCX905... | Answered on Apr 13, 2010
Use the following steps to reset the base to factory settings for all TRU models:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Tech support, this is supposedly all it takes to reset the phone.
Uniden TCX905... | Answered on Mar 09, 2010
MAKE SURE THAT INSIDE THE HANDSET THE MODEL TCX905 SHOWS, IF IT SHOWS A DIFFERENT MODEL IT WILL NOT WORK.
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
HI,
It seems that it was a internal problem, a possible short circuit on the main board of the unit and it will need an immediate repair.
Hope this helps
Uniden TCX905... | Answered on Oct 22, 2009
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Uniden TCX905... | Answered on Sep 29, 2008
rewire the jack. Obviously there is a wire not connected
Uniden TCX905... | Answered on Dec 26, 2007
Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
Popular Tags
33 questions posted
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
bought some handsets but
  • Lands Phones
