Comcast xfinity remote control code won't work. Too old to find the tv model number on back. Silver remote with red ok/select model of remote. Northeast Massachusetts. Thank you.
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
SOURCE: Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
SOURCE: Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
SOURCE: comcast remote will not program for this tv
Try using the search function
use code 991 then keep pressing power then tv on the top of the remote till the tv turns off then press setup if that doesnt work its not available.
SOURCE: Comcast remote cannot operate Funai/Sylvania
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
