20 Most Recent
Sylvania LC-225SL9 22 in. LCD TV Questions & Answers
Comcast remote cannot operate Funai/Sylvania
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
12/28/2013 7:48:54 PM •
Sylvania...
Answered
on Dec 28, 2013
My tv wont come back on
Check the power cord to the television if you are unable to turn it on with the "Power" button on the front. Make sure the cord is connected properly to the television and to a working AC outlet. If a power outage has occurred, unplug the television for 30 minutes to allow it to reset and plug it back in.
2/1/2013 1:03:52 PM •
Sylvania...
Answered
on Feb 01, 2013
The picture is too big.
on remote go to menu there should be a way to set up picture side it will say zoom and so on
4/18/2012 7:50:21 PM •
Sylvania...
Answered
on Apr 18, 2012
The tv turns on and digital tv comes up on the
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
12/9/2010 9:30:26 AM •
Sylvania...
Answered
on Dec 09, 2010
Does the Sylvania 22 HDTV require a special cable
Not necessarily. You can use the normal connecting cable but you may not get HDTV picture.
Better is to connect through HDMI cable where you can view HD pitures on the channels transmitting HD programmes
1/6/2010 5:38:40 PM •
Sylvania...
Answered
on Jan 06, 2010
I need codes for Directv remote for my sylvania
Direct TV remote numbers they list for sylvaina are. 10054 or 10030 or 10171. Keep in mind that universal remotes will not necessarily operate every feature of your TV. Try each code, one at a time. Check the volume and channels up and down and the power buttons before assuming the code is wrong. If these do not work I can find the code but I will need the model nember for your TV.
8/6/2009 4:25:09 PM •
Sylvania...
Answered
on Aug 06, 2009
I have no remote. Need to adjust the veiwing size of screen.
You'll need the remote to fix the problem, because it has the SCREEN MODE button.
The cheapest place I can find one for you is at NewRemoteControl.com. It's going for $32.95
Just put "LC225SL9 remote" as your google search. You'll see the remote pop up on the shopping part.
3/23/2009 3:49:00 PM •
Sylvania...
Answered
on Mar 23, 2009
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work.
Let's troubleshoot the issue and try to get it working:
If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why.
Check Power Cord and Connections:
First, ensure that the power cord is securely plugged into both the TV and the electrical outlet.
If you suspect a faulty power cord, consider trying a different one.
Reset the TV:
While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset:
Unplug the TV's AC adapter from the electrical socket.
Press and hold the Power button on the TV for 20 seconds.
Plug the AC adapter back in and turn on the TV.
Check Audio/Video Cables:
Inspect the audio/video cables connecting your TV to the satellite or cable receiver.
Ensure that the color-coded prongs match their respective connecting points.
Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs.
Inspect Coaxial Cable:
Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN.
Confirm that the connection is firm; a loose coaxial connection can cause display issues.
Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure.
Check for Interference:
If distortion continues on the TV screen, consider nearby interference.
Power-hungry appliances can cause electronic interference, affecting display quality.
Visit a Repair Shop:
If the above steps don't resolve the issue, you may need professional help.
Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering.
If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM •
Sylvania...
Answered
on Feb 03, 2024
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
- Auto Code Search:
- Turn on your Sylvania TV.
- Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
- Press the "TV" button on the remote to set it to control the TV.
- Press the "Power" button repeatedly until the TV turns off.
- Press the "OK" or "Enter" button to save the code.
- Manual Code Entry:
- Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
- Press and hold the "Code Search" button on the remote until the indicator light stays on.
- Enter the code using the number buttons on the remote.
- Test if the remote now controls your TV. If not, repeat the process with a different code.
- Try Common Codes:
- Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM •
Sylvania...
Answered
on Jan 09, 2024
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM •
Sylvania...
Answered
on Nov 05, 2023
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD.
https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
10/20/2023 4:15:16 PM •
Sylvania...
Answered
on Oct 20, 2023
