Televison & Video Logo
Posted on May 04, 2009
Toshiba md12m1 tv/dvd, original remote needs reprogramming
I have a Toshiba tv/dvd combo. Until 3 days ago, original factory remote worked fine. Daughter tried to use my remote to program her new Toshiba TV, and now my remote no longer works with my TV. Batteries have been replaced with new. Toshiba customer service was no help. Any suggestions?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
541
Points
I have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Codes for uneversal hd toshiba dvd combo tv
A universal is not likely to work for a combo unit---best bet is to Google the model number of the set and try to get an Original remote for it.
I lost my original remote for my toshiba tv model MW20F51 and found a toshiba wc-sb2 remote. is there any code i can use to sync them
No.Might some functions work, because they are both toshiba tv.Try website 1-800-Remotes Factory Original.Get the sanme exact remote or very simular.
I have a Polaroid 1913 TDXB with the original remote just a few days ago it stopped working it has fresh batteries. I assume the remote has reset it's self is there a code for it?
Take the remote aparts,clean it with a Q tip with some rubbing alcahol.Clean the rubbers films and the circuits board.Clean IR in the tv and the remote.After this still don't work ur remote it dead,by the main CPU,it junk know.Here a website to buy a new one 1-800-Remotes Factory original.Never have need codes for oiginal remotes.
I have lost the codes to program remote for Toshiba MV20FK3.
Code 109 tv 015 VCR 167 DVD might work.
this ur oringinal remote?not go on 1-800-remotes Factory original website buy ur original remote.
1helpful
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
1helpful
3answers
NEED TV CODE TO REPROGRAM MY REMOTE
Hi
Had the same problem but found a similar looking remote for the SDV593SU online and the codes work!
http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
Cheers!
Michele
1helpful
3answers
Tv/dvd
Try ordrer the original remote contrl by Tv's manufactory. Aleixo
Lost factory remote
you need the remonte control original bath this situesen you need the selection deader cod four your remont controler
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
