My windows 7 operating system could not load due to an error message on the screen upon 2-3 minutes after start up button. What could be the proble and how do i solve it?
Http://store.acer.com/store/aceramer/en_US/eRecovery
here you can order your recovery disk and load the os with no problems it may cost you around $26 buck
SOURCE: Driver error upon boot
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
SOURCE: error loading operating system
Here you go!
SYMPTOMS
loadTOCNode(1, 'symptoms');
When you restart your computer after the file-copy portion of Windows XP Setup, you may receive the following error message:
Error loading operating system
CAUSE
loadTOCNode(1, 'cause');
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
RESOLUTION
loadTOCNode(1, 'resolution');
Warning This article contains steps that may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change your BIOS settings at your own risk. If you need help with any of these steps, contact your hardware manufacturer and note that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
To resolve this issue, use one of the following methods:
Make sure that you are using the latest BIOS revision for your computer. Contact the computer manufacturer to inquire about how to obtain and install the latest BIOS update that is available for the computer.
If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site:
http://www.pc.ibm.com/ww/hdd/hddredirect.html (http://www.pc.ibm.com/ww/hdd/hddredirect.html)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
SOURCE: Error loading operating system
Press the F2, and laptop will go to the bios where you will be able to change the boot order from the hard drive to the optical drive.
SOURCE: Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
SOURCE: error loading operating sytem
press F8 after pressing power on button and boot in Safe mode...
or u need to repair it using the Windows CD
