I just installed Frontier DSL All of my wireless devices connected except 1 older PC that is running Windows XP I called tech support & they said everything is set up correctly. They said that windows must not have been updated. I have updated windows and the pc still does not connect. Any ideas?
SOURCE: wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
SOURCE: EMbarq/Zyxel 660R/eHarmony/Windows Don't Play together well
Upgrade to the latest firmware on the modem, disable the modem firewall, or bridging the modem will resolve this
SOURCE: Actiontec GT 704 WG Verizon to Frontier
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
