you have changed the wifi/ ether / web setting for camera and this is why when you go to another place and use it. it works check the settings on the camera there will be a rest panel on the setting press this and see if that helps you problem.
There could be a lot of reasons, one is port blocking, the other is firewall, there caould also be NAT port issues, what modem and internet provider do you have could be the problem.
Try it with another program like skype or google hangout. You may not have the correct driver installed. If that is the case, google the model number of the unit and download its correct driver.
perhaps you should address your problem to omegle as it's their interface that doesn't recognise your camera and there are no user settings as I can see. maybe you've got skype running in the background, or some other app that uses your camera - this will prevent any other app from using it.
Download updated drivers for your webcam and then try to use omegle. You can find drivers at the following link, click here. Be sure to reboot your computer afterwards.
On the one I just fixed, Skype would not even see the LifeCam. I had to go into the registry and delete the calls for the Lifecam in the run section. Open Regedit, back it up first then delete any referecne to Lifecam in HKLM\Software\Microsoft\current version\run and also HKCU\Software\Microsoft\Current Version\Run
Be careful to ONLY delete the referecnes to Lifecam. If you are nto familiar with the registry you can seriously mess up your file system.
