Freezer is keeping food frozen but fridge is not keeping things cold at all.
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
SOURCE: Fridge and freezer not cooling right
Due to the ice still being made , this indicates yout freezer fan is working . The ice maker has to be 5 degrees to work , which also indicates the refrig IS NOT low on refrigerant . May not be pulling enough cold air forcefully enough to send into the refrig section which indicates a defrost problem . The warmer freezer food also indicates that not enough cold air , is dropping to freeze the food except in the lower portion of the freezer .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
SOURCE: fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
