Your local Pride Mobility dealer can order your parts. Please go to Pride on-line: http://www.pridemobility.com/locator/index.asp and enter your zip code.
CHECKING THE LEDs
The following procedure applies to all of
the LEDs.
1. Check:
LED (for proper operation)
a. Disconnect the meter assembly coupler
(meter assembly side).
b. Connect two jumper leads 1 from the
battery terminals to the respective coupler
terminals as shown.
WAWRNARINNGING
• A wire that is used as a jumper lead must
have at least the same capacity of the
battery lead, otherwise the jumper lead
may burn.
• This check is likely to produce sparks,
therefore make sure that no flammable
gas or fluid is in the vicinity.
c. When the jumper leads are connected to
the terminals the respective LED should
illuminate.
Does not light ® Replace the meter
assembly.
This will tell you if it is the meter, If the meter is good then you will need to follow the wires connected to it till you find the problem. I hope this is a big help to you.
7
