Craftsman Tecumseh Snowblower 7hp Carburetor Cover 34672 Logo
m
murry frank Posted on Oct 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know what size chain for drive on craftsman2 8hp 27" snowblower
  • Anonymous Mar 28, 2014
    Chute rod not attached
George
Level 2:
Sergeant:
Champion:
  • Expert 320 Answers
  • Posted on Oct 25, 2013
 George
Expert
Level 2:
Sergeant:
Champion:
Answers
320
Questions
Helped
158696
Points
506
Look on the unit and find the model number. It usually starts wit 917.
Find it and then go to sears.com and type in the model number.
2answers
What size tire chains do I need for 2015 craftsman snowblower model 247.886940
sears website will have the correct ones listed for your machine
2answers
What is the auger belt size for craftsman snowblower model C950-52151-1?
https://www.google.com/search?q=C950-52151-1&rlz=1C1CHBF_enUS757US757&oq=C950-52151-1&aqs=chrome..69i57.655j0j4&sourceid=chrome&ie=UTF-8
No drive gears
ok ther is clutch Disc and it,s worn out need to replace it or the drive gear is worn look for broken rubber ring
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
I have an old snowblower (ca. 1980's?) that runs like a top - the only problem is that the auger drive chain pops off the rear (smaller) sprocket in heavy snow, no matter how tightly (or loosely)
First remove the chain--- lay it flat on the floor --streched lengthwaze . grab either end and pull out and push back--- if chains length moves more than a quarter of a inch ---replace the chain. Next inspect the sprokets, if they are worn inward on the side they will let the chain drop on too far making the chain jump and rattel as it runs and this will throw the chain. Next inspect allignment of each spoket to the next sprokets with belt drive the belt will flex and this is not critical with chain drive this will load one side of each spoket causing the chain to jump off.
Apr 21, 2013 • Garden
2answers
I need to know spark plug gap on murrays snowblower g2250030
.30 is usually a good standard if you can't find the manualHave you tried manuals on line ?
1helpful
Broke the chain , on snowblower
top idler sprocket was out of alignment,staitened plate it was attached to, then chain was running true and went on just fine. it was an old wheel horse snowblower.
Dec 15, 2009 • Garden
Chain Size
Go to a web site like bikebandit.com and pick the make year and model of your bike to see the part diagrams. Find the drive chain page and it will usually tell the size of the chain.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
