Something is very wrong here. Does this occur when running on internal battery or only when plugged into the power adapter? At these temperatures the cooling fan should be running at full speed constantly until the temperatures fall to about 50 centigrade or lower. (dependant upon loading and CPU power consumption.) The laptop should automatically power down at the temperatures you are quoting!
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me! Daniel • [email protected] • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
525L series as very matter that cause to emliminte the problem try this matters lst.
step1 the power is 300watts -/+ any power supply that above the usage will be overload maybe thats the problem when your cpu & does't power. what are the devices that u plug it to the ups? it important what the devices u plug in maybe using high watts for eg printer, scanner and fax mechines. the solution unplug out those not important device and plug your cpu to test and see it work? and also the socket you plug it in from th cpu, try to plug one of the device to test and see if the power socket is working.
