20 Most Recent HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Questions & Answers
2answers
Laptop HP Pavillion zd7000 (model zd7058cl) does not turn on
May be this sound crazy, but helpful to me in many cases. Unplug all easily detachable parts and press turn On key for 20 to 30 seconds. Again resemble it and try to turn on. I hope it will work fine. if not don't waste your time and contact to local or online repair center.CheersJohnFor any Tech Query: +1 (844) 355-5111 (toll-free)
4/17/2017 11:49:15 AM • HP Pavilion... • Answered on Apr 17, 2017
HP Pavillion zd 7000 (model zd7058cl) does not turn on now
Don't try again and again,,, if not running well protection circuit will turn off. therefore test for short circuit, need to remove unwanted parts and try, also need to test the circuit for short circuit with multi meter.specially mosfets need to check.
4/3/2017 5:42:21 PM • HP Pavilion... • Answered on Apr 03, 2017
8answers
Hp laptop charger is hot!!!!
it just happened to me it got over hearted and the fan in it is brunt wich make the noice u have to get a new one
8/11/2014 3:10:12 AM • HP Pavilion... • Answered on Aug 11, 2014
Hp pavilion zx5000 power up but black screen
My suggestion would be to unplug the cord from the connection on the computer, then remove the battery. After you've done that, press and hold the On/Off switch for about 60 seconds, then, after you've done that connect everything back together, and see if it will reboot. If not, check the hard drive, and the ram and make sure they are all connected tightly.
10/22/2012 10:36:31 AM • HP Pavilion... • Answered on Oct 22, 2012
Computer keeps shutting off
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
10/9/2012 11:05:21 PM • HP Pavilion... • Answered on Oct 09, 2012
Laptop doesn't charge
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC AdapterCheck to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the BatterySometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
10/8/2012 10:56:49 PM • HP Pavilion... • Answered on Oct 08, 2012
2answers
Ac adapter for hp pavilion ze 4900
Go to spare parts shop you can resolve your problam with min price
1/1/2012 11:55:01 AM • HP Pavilion... • Answered on Jan 01, 2012
2answers
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
8/16/2011 5:52:49 AM • HP Pavilion... • Answered on Aug 16, 2011
Computer beeps at startup, goes
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver make sure the lead has a secure seating if applicable or the usb device hope this helps
6/4/2011 9:08:36 PM • HP Pavilion... • Answered on Jun 04, 2011
Battery does not hold a
You need a new battery.
5/17/2011 7:42:11 AM • HP Pavilion... • Answered on May 17, 2011
2answers
HP laptop, wont turn on...
I have the same model with the same symptoms in for repair. This is a motherboard issue and requires a reflow of the GPU and chipset. It has nothing to do with the LCD because the buttons don't react when the laptop is "turned on". The touchpad turn on/off button does not react when pressed, the same is with the wifi, volume and mute buttons.
The problem is in a poor solder and a cracked/oxidized contacts due to heat buildup.
3/3/2011 9:44:48 PM • HP Pavilion... • Answered on Mar 03, 2011
Hi, hp pavillion zx5000 will
I would try the following steps, then contact HP (if these don't work, chances are it's hardware related).
1) Remove the battery and power cable. 2) Hold down the power button for 3 seconds. 3) Reattach the power cable and battery. 4) Try to boot again.
3/1/2011 3:20:08 PM • HP Pavilion... • Answered on Mar 01, 2011
HP Pavilion zd7000 will not power on at all I have
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your dvd\cd drives have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
2/18/2011 8:01:50 PM • HP Pavilion... • Answered on Feb 18, 2011
My laptop cuts off by itself
You may have a heat problem.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
2/12/2011 5:25:03 AM • HP Pavilion... • Answered on Feb 12, 2011
This site is a joke!
Please tells your problem.
Get the info of your adapter here
gadget-for-you.co.cc/laptop-ac-adapter-for-hp-zv5000.aspx
1/23/2011 4:16:16 AM • HP Pavilion... • Answered on Jan 23, 2011
HP ZD 7000 wont power up. Will plug in, power
I had a similar though somewhat different problem. My zd7000 was plugged in but it was oscillating between charging the battery and running from the battery. In the past I'd adjust the jack position and life was good - this time nothing mattered. I turned the laptop off and noticed that the charge light came on and stayed on - I guessed something was freaky with the battery so I switched to my spare - the charger light came on, I turned on the power I had a brief power on followed by zzzzttt then everything died. I could smell the stench of electrical burning. I disassemble the whole laptop and removed the motherboard - the back of the power jack is burned. A new jack is $10.
If I had to guess, I"d guess you have a bad jack. I've seen offers to repair this on the net for $100. If the offer is legit, I'd rather pay the bucks - theres only 5 billion screws in the laptop - plus the risk of static discharge damaging to boards or the pain of getting the processor heat sink out without damaging the processor and then getting heat conducting "grease" between the processor and the heat sink when you put it all back together again. I figured my unit was dead anyway, might as well see if I could find the issue. Now I need to get a new jack - and see if I can get it all back together again...
12/13/2010 9:39:50 AM • HP Pavilion... • Answered on Dec 13, 2010
My slimline 3000 won't boot
Hello Camilo,
Let me give you an advice that you can try out.
It is possible that your processor is over-heating, maybe because of your environment, possibly because the air-vent is blocked, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
If the two of them are not working, then try to get a RAM of the same type to test it with, either from a friend or a technician.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me know how it goes after you've tried this.
Hope this helps you out.
12/4/2010 5:26:44 PM • HP Pavilion... • Answered on Dec 04, 2010
2answers
My HP Pavillion entertainment laptop shuts down
this you power outlet is abnormality inside..need change a new.
11/23/2010 7:47:30 AM • HP Pavilion... • Answered on Nov 23, 2010
I have no power to my zv 5000(hp). It has the
First of all, disconnect your battery from back of the
laptop, then try and get a friend or a technician that
uses the same type of laptop, and try to swap the
battery just to check whether it works and charges
it properly. Also do the same thing with the
Adapter/Charger and charge it with it.
This is because, there are two diagnostic possibilities
here:
1.) It is either the battery that you bought is not good
and you need to return it quickly before its too late
or;
2.) The charger that you are using is bad, or not
supplying enough current to charge the battery
cells...and this might even damage the battery after
a while, or make the battery not to charge to its full
capacity and as well discharge quickly.
Try this out and let me know how it goes.
Goodluck and thanks for using fixya.
11/12/2010 7:01:02 PM • HP Pavilion... • Answered on Nov 12, 2010
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
111 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
pavilion zd7000 zx5000 zv5000 presario 3
  • Computers & Internet
