Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
A
Anonymous Posted on Oct 02, 2013
Steering quit working, cables have slack - Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor
2helpful
I have a 91 ford f150 and have a lot of slack in the steering it's seems to be in the gear box is there any way to repair or take the slack .
Many components in your front end can cause slack in your steering. ball joints, tie-rods, etc... Make sure that all these components are in good repair. THEN if you're confident that your steering box is faulty you can go to the site below and get one from them. They're known for building excellent steering boxes for ford trucks and broncos. I believe you will need to send them your core and they will send you back a remanufactured (better than oem) one.
http://www.redheadsteeringgears.com/Inventory.html
1helpful
2answers
Clutch is slipping on my 2008 flhx how do [ adjust clutch beyond adjustment in cable
take all slack out of cable . take derby cover off loosin lock nut in center if pack tighten addj screw turn in till seats back out 1/2 to 1 turn tighten lock nut . take slack out of cable . hatleytalking.con ...good luck
Hayne's Manual for 1986 Taurus lead me wrong! After removing everything I can, I still cannot "reach up behind instrument panel" and even come close to touching the speedometer cable connection....
if its a manual cable you just unscrew from transmissionwill be at your gearbox and remove all cable ties holdinding outer cable might give ya enough slack to remove from dash end
I think my tyrod may be disconnected. How can I be sure?
I assume you mean tie rod, which is part of the steering mechanism of any vehicle.
The tie rods connect the individual wheels to the steering box AKA steering sector via a ball and socket type of flexible joint.
If a tie rod is disconnected, you CANNOT STEER your car. If one is badly worn, you will experience a lot of slack (lost motion) in the steering wheel and quite likely hear a popping sound as well.
If you are unsure, consult a local mechanic before attempting to drive the car, as this could be very dangerous and lead to a crash.
3answers
I have a 97 K1500 with some loose steering issues. I have replaced everything that has anything to do with steering except steering gear and powerstearing pump and it all helped a lot but it still seems to...
Have the front end alignment checked as it may the cause of wandering. With the truck parked and the steering centered, but the engine running, wiggle the steering wheel back and forth while watching the left front wheel. It should respond to the steering action without any observable slack. Have someone watch both front wheels while doing this and see if there is slack between the two wheels. Any slack here is indicative of slop in the cross-wheel coupling. Hope this helps!
I HAVE A 1998 FORD EXPEDITION AND A SCREW CAME OUT OF THE STERING WHEEL. AND NOW I CANT PUT INTO PARK. HOW CAN I FIX IT
I have encountered this quite a few times and it requires either dropping the steering column or removing the instrument cluster to access where the bolt goes. Normally before the bolt falls out you will notice you have some slack in the shift lever. The bolt that usually falls out on the fords has a torq/allen hole in it. These bolts hold the shift lever to the steering column.
2helpful
2answers
The gear shifter handle moves but the van stays in park . The gear shifter handle on the steering colum, will move up and down very loosely. The indicater for park, reverse, neutral, and drive will move to...
there is a cable attached to your transmission that is actuated with that lever. the cable has come disconected or has broken. open your hood and look for cable on top of your transmission to see if it is worn.broken ect. helps to have somebody move lever while u locate it if you are not sure what you are looking for.
9helpful
2answers
1/6 turn of slack in steering
On top of the steering gearbox, is a threaded stud that has a slot in the head of it, and a nut on that stud.
Make sure the wheels are straight. Use a large flat tip screwdriver for that stud, take an end wrench, and loosen the nut.
Screw the stud down 1/8 to 1/4 turn. Tighten the nut. Check the slack. If the steering is too tight, back it off. Too loose, tighten a little more.
Drive the vehicle a few blocks, check the steering out. Come back, and do adjustment some more if necessary.
It's a fine line between too tight, and removing slack. DO NOT drive it being too tight. Readjust until it's right.
If your vehicle is an '83 Jeep, it's 26 years old. The steering box may be worn out.
1helpful
Motorcycle wont go
is there any slack in the cable, i mean can you pull the clutch lever in just a bit with no tension? im not certain with that bike, but there my be a internal adjustment that may help. if not then its likely you need to replace the clutch plates. hope this helps..
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
