SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
SOURCE: losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
SOURCE: Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
SOURCE: Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance. I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online. While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what. I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
