SOURCE: I have a Samsung HP-S4253X/XAA Plasma with coloration problems
The problem is normally called "Diffusion". It's the most common problem I come across on Plasma televisions. If this is your problem, then, the VSCAN and/or the VS must be adjusted (usually counter clockwise about 10 volts). The VSCAN is adjusted first and will remove most, if not all the diffusion. If you need a technician in your area, contact Samsung at: 1-800-samsung. If you like, respond to this post with a picture and we can analyze it further.
SOURCE: VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
SOURCE: LN37A550 LCD TV has washed out image
It is possible the problem is caused by a wrong option byte setting in the service menu. The correct setting depends on the type LCD panel used in that version. Version number can be found on a sticker on the right side of the television. A bad main board or TCON board can also cause that type of problem.
SOURCE: Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop
mode or demo mode.
How to get out of "Shop
Mode"
1. Press [Source] to get to the Air or
Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself
(not the remote)
Next step must be completed while
the volume bar is still on screen
3. Press and hold [Menu] on the TV itself
(not the remote) for about 7 seconds
If the screen
flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode
is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the
alternative way below
Alternative Method
Press [Source] on TV remote to get
to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight
SETUP and press [Enter]
Press [Enter] again on PLUG AND
PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or
choose an alternative language
Press [Right Arrow] to highlight
HOME and press [Enter]
Press [Menu] repeatedly until you
see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by
pressing [Info] on the TV remote
