SOURCE: cant find the 20 amp fuse on my husqvarna yth2148 riding mower
Find the solenoid and on the side the battery cable is hooked to is another smaller red wire that has the inline fuse on it.
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: I have a Husqvarna model yth2148 riding mower that
My friend has one that bent the push rods and lose power , we are tring to find out what cause this problem, its a yth 2148 Brigg & Stratton Vanguard. If any one knows e-mail me @ [email protected].
