Weedeater Gas Blower Logo
mike mitchell Posted on Sep 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won stay running
Starts but want stay running
Geterdun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 184 Answers
  • Posted on Oct 18, 2013
Geterdun
Expert
Level 2:
Cheetah:
Answers
184
Questions
Helped
97306
Points
244
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Starts but won't stay running
Did you changed fuel filter.
1helpful
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
2answers
Honda accord 1994 will start but won't stay running
Does it stall as soon as you let go of the key
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Won`t crank
check your fuel pressure and also check your plug gaps and make sure you have a stong spark, you say it stays running once started on ether? does it run well or poorly? is it drivable or not please explain in more detail -please rate -jeff
Top Weedeater Garden Experts
vince
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
