20 Most Recent Weedeater 25cc Gas Blower () Questions & Answers
Carburetor mainjet is probably clogged.
Weedeater 25cc... | Answered on Dec 20, 2017
fit new diaphragms in the carby
don't alter any settings
just undo the housing screws and replace the diaphragms
Weedeater 25cc... | Answered on Dec 12, 2017
Hi Joyce,try 015" thats 15 thousands of an inch.with imperial feeler gauges.Cheers.Ronnie.
Weedeater 25cc... | Answered on Aug 16, 2015
Ethanol gas wrecks Carburetors and Gas lines. Just for giggles see if the Stone filter in the gas tank broke off the dried out gas line.
Weedeater 25cc... | Answered on Jul 01, 2015
Initial start adjustment is 1 full turn out on both low and high side.
Weedeater 25cc... | Answered on Oct 15, 2014
50:1 gas & oil mixture seems to work
Weedeater 25cc... | Answered on Oct 03, 2014
Could have scored the rings, broken ring, or just cooked the piston to the sleeve, maybe melted the connecting rod to crank, damaged needle bearings. Most likely needs to be taken apart.
Weedeater 25cc... | Answered on Mar 24, 2014
Use fresh and high octane gasoline
Weedeater 25cc... | Answered on Nov 12, 2013
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Weedeater 25cc... | Answered on Oct 21, 2013
It sounds like the engine might be running too lean. You need to get someone to adjust the idle and high speed screws correctly.
Weedeater 25cc... | Answered on Sep 10, 2013
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
Weedeater 25cc... | Answered on Dec 15, 2012
you are right, check your fuel filter, fresh gas and clean your carb out,also check your exhaust screen for being plugged, also a bad fuel cap could cause this, if the cap is not venting
Weedeater 25cc... | Answered on Aug 01, 2011
Check the fuel filter in the tank and make sure the fuel line is connected to it. The carburetor may have inhaled some debris and/or small chunks of broken fuel line and need to be opened up and cleaned also. At this point, you would probably need to install a new fuel filter also.
Weedeater 25cc... | Answered on Jan 16, 2011
Anything under 100 psi after 5 good pulls would suggest it has internal damage or wear.
Weedeater Garden | Answered on Oct 24, 2019
Weedeater 25cc Gas Blower () Logo
39 questions posted
Top Weedeater Garden Experts
Charles Tidwell
Mike Ceslow
 Russ Hill
Russ Hill
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
View Most Popular
Weedeater Garden
  • Weedeater Garden
Most Popular Question
weed eater lower start reasonably but
  • Garden
