SOURCE: Need to reset phoenix bios
have yout tried this application..
http://www.cgsecurity.org/wiki/CmosPwd
I've heard before about the toshiba paralell loopback (it's also mentioned on the website above) as a way to unlock your bios you may want to try that aswell.
post back if it worked.. would be good to know if it did.
I remember also reading about the possibility of flashing your bios (you're going to need a floppy drive unit) to at least unlock your hard drive and get your data out, you may still not be able to hack into the bios again.
SOURCE: reset
when i open my latop toshiba A215-S5822 that time it shows enter password..bios passwork block in laptop plz send me a solution to solve this problem....thank u
SOURCE: toshiba satilite a215 s7422 bios password how to cleare
You'll need a special tool that only Toshiba has. I believe you can get yours cleared for FREE if you tell them that all of a sudden out of nowhere you have a bios password. Stick to that story because they've already admitted to the problem with many of their laptops. You'll have to find an authorized Toshiba repair center to take care of it for you. Otherwise I believe they charge around $100 to clear it.
Don't bother to try the cmos battery trick, it doesn't work on your model. The password is stored on an onboard chip.
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
