Use the search engine /downloadanystuff.org/ for downloading any driver. Just search for any software/driver name/downloadanystuff.org/ and you will get the best link to the same. Click on the category Software/Driver if you want to refine your search.Its cool and finds almost all FREE sharewares etc
Sometimes the newer print drivers don't do everything the older ones do. make sure you have a Vista print driver, and that the Vista print driver has that function (my HP Vista driver wouldn't scan for about the first year until HP finally updated the driver) Make sure you have the latest release of the vista print driver. if the problem is the vista print driver, sometimes you can get lucky by running/installing an XP driver on a Vista machine, in XP compatibility mode (right click, compatibility)
There is no official driver for mustek 1200 for vista, due to it's age, but you can try installing the one intended for XP from: http://www.mustek.com.tw/Download/driv_scanr/europe/1200ed.html .
As far as I know, you don't need special drivers for HP Deskjet printers in vista, due to system having integrated drivers. But in case that the system doesn't recognise the device you can try with xp drivers (since there are none officially for vista) from: http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=emea_africa&lang=en&softwareitem=dj-14939-2&os=228&product=375447&
Soundmax vista driver: http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Analog-Devices-SoundMAX-AD1988-Vista-Driver-610026110-WHQL.shtml
To use it with Windows Vista, you must install the driver software for Windows Vista.
The Windows XP drivers for your product cannot be used under Windows Vista.
Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before
upgrading your OS from Windows XP to Windows Vista, delete / uninstall
all the Windows XP driver software first; then, upgrade the OS to
Windows Vista and install Vista driver software. If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall the Windows XP drivers before installing Vista drivers.
Normal
0
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
I have had the same issue, Try this on an xp machine with driver loaded for dc1250 share this printer and then on the vista machine brouse the network and double click the shared printer on the xp machine and the driver should load and vista will print using the xp machine as a print server. Les
