20 Most Recent
3Com SuperStack 3 3824 (3cr17402-91-uk) 44x1000 Mbps Networking Switch Questions & Answers
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations.
Use the password recovery method outlined below to define a new password for the "admin" user account:
- Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
- Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
- When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
How to check if the switch is manage or unmanaged
Managed switches you can enter the default ip into a web browser, login and "manage" settings" this default IP will be vendor specific. Unmanaged you just plug in devices and that's about it. Managed switches you will pay a lot more for. Some lower end ones maybe several hundred dollars and up. If you are buying switches at Best Buy they are almost all unmanaged.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
