SOURCE: I have a Toro zero turn commercial 60
im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
SOURCE: toro recycler rear bagger linkage set-up to
Hopefully, this will clarify it..
http://small-engines.com/bsgovernors.html
SOURCE: I have a 05 Toro 44in ZTR with a 19HP Kawasaki
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
unplug wire form temp sensor on right side of engine and then try to engage pto
Im having similar issues with a Kawasaki FH680V (23 HP)
Ive changed the stator, regulator, and both ignition coils. My next guess is that it needs carburetor, but the cheapest I can find is like $170 on eBay, they are nearly $400 at the local mower repair shop.
