Refrigerators Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore coldspot top freezer auto ice maker, water
Kenmore coldspot mod 78942891 mfg date 06-99 top freezer auto ice maker, water will not shut off when ice tray is full
Anonymous
Level 2:
  • Expert 190 Answers
  • Posted on Apr 08, 2009
Anonymous
Expert
Level 2:
Answers
190
Questions
0
Helped
78964
Points
619
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
1helpful
Question about size of Kenmore Coldspot Refrigerator
What Are Some Specifications of the Kenmore Coldspot ...
https://www.reference.com > World View
The Kenmore Coldspot 106 is a 20.7-cubic foot side-by-side refrigerator with a reverse osmosis Pur water filter, ice maker and digital controls.
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
WATER IN BOTTOM OF Kenmore coldspot 78942891
Is the compressor working? Check to see if it is hot.
2helpful
I have a Kenmore Coldspot (mfg date 10/00), model 106.70192001. The ice maker is NOT hooked up (by choice) and for the last several weeks, there has been water draining from freezer into fridge in a cyclic...
Your drain line is frozen and is not allowing the defrost water to drain to the pan below. You will need to remove the rear panel in the freezer and thaw the drain line. Make sure ALL ice is thawed before reassembling. I would recommend installing a drain heater so it will not happen again. They are inexpensive and easy to install. They come with complete instructions.
Kelly
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Ice maker leaking
yes go to sears parts center and buy the ice maker part # 4317943 thats if the ice maker is in line is leaking because the mold inside is peeling off due to the wtr being to hard repl ice maker is realy easy loosen screws remove harness and repl new one that is all you might not need all parts in box
4helpful
2answers
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
2answers
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
