SOURCE: I have lost my user guide manual for my Philips
Go to http://www.dictation.philips.com/index.php?id=71&CC=UK#result and you will find you manuals under Mobile Dictation section.
I hope this helps...
SOURCE: I have an old Philips Professional Pocket Memo 398
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
SOURCE: Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
SOURCE: phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
