SOURCE: error 01 tamron lens 70-300 mm af 4-5.6 with
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
SOURCE: Tamron 28-75 SP AF XR
You didn't state whether you are using it on an APS-C or a full-frame SLR, but that lens is known to be very soft and unsharp especially at the edges until you stop it down below f4. It also exhibits strong vignetting until you stop it down.
The effects are far more noticeable when using a full frame sensor.
Some production examples will be worse than others, and some users will notice the unsharpness more than others. You clearly find the performance to be unacceptable, but it is mentioned in almost every review of that lens. Your lens is not unique in the weaknesses it exhibits as most lenses perform worst at wide open apertures.
You have discovered one major reason why some lenses are cheaper than
others, and why lenses designed especially for low lighting levels are
hugely expensive..
Your only real fix is to try and avoid shooting at apertures of f4 and larger. If that's unacceptable to you and you need a lens which performs well in low lighting conditions then you can only return the lens for a refund (much easier if you live in the UK due to the Sale of Goods Act). If you cannot get a refund then I suggest you sell the lens and buy a better quality replacement, or better still replace the zoom lens with fixed focal length prime lenses.
Zoom lenses are always an optical compromise, particularly so with zooms covering the wide to short telephoto range, and now that many dSLR's can produce low noise results at very high ISO settings there's less demand from customers for manufacturers to make lenses which have outstanding performance at wide apertures at higher cost.
SOURCE: What's your pwill Tamron AF 1780 Lens 80mm - 210 work on a sony 200A dslrmmroblem?
Tamron makes their lenses with a variety of lens mounts. A lens with a Nikon mount, for example, will not work on a Sony camera. Assuming the lens has a Sony mount then yes, it will work fine on a Sony dSLR.
