La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
A
Anonymous Posted on Aug 06, 2013
Wind direction and speed stopped working. The wind chill some times works. It's been great for two years. Help.
Just bought 05 gsxr 750 and at idle it running 220. is that normal
If it's 54 outside and the fan is not running because the cold air is passing through the radiator and the coolant is doing it's job. Then you come up on a red light and basically all of the sudden that 54 degree wind chill has somewhat stopped (because 54 degrees outside and going 50 mile per hour creates quite a wind chill) the engine will heat up, cause the thermostat to open allowing the fluid to flow through the system. Now the fan kicks in at 220 degrees and begins to cool everything back down or you start riding and the wind cools it back down again...........I hope this helps a little. My bike heats up quickly too especially after riding for awhile and then stopping at a red light. I flush my coolant system yearly before the winter. It's generally recommended every 2 years.Ref: https://www.gixxer.com/forums/80-06-07-gsx-r600-750/294175-rapid-heating-idle.html
Mar 13, 2019 • Motorcycles
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Won't show outside temperature or wind speed
Have you changed the batteries in the outdoor temperature sensor?
Manual
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 • Boating
2answers
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 • Watches
2answers
Omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Top La Crosse Technology Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
