trun unit on let it setup .... fill water up ....let it heat up until ready ....when it trys to flush through turn the steam valve open fully... pump will then clear air lock ...when it sounds quieter turn steam off...job done. bsc appliances 07779933829 postal service too.
gwm_inc, Please verify all speakers work or are not shorting the outputs of this Yamaha 100w/ch amp. Also this unit could have bad capacitors and or failed output transistors if the speaker terminals or connecting cables get shorted. I would guess that the power supply is detecting a FAULT condition and is shutting itself down to prevent a catastrpohic, nonrecoverable failure event!! Best shot would be to have a technician evaluate unit. 12fixlouie
please check the input connecetor could be the losse conact with the wire some times it happens with this type of sound try to play the system and move the connector if the sound trun go replace the input cor
have your altinator check at your local parts store. if that doesnt work chek the grounds to make sure they are good and tight. but it does sound like your alt is going bad
