Samsung Q430 Laptop Logo
A
Anonymous Posted on Jul 30, 2013
HOW TO I GET MY SMARTBOOK TO CHARGE WITH USB CHARGER IN MY COMPUTER
Sylvania manual
Hi Zeda,
it seems like your battery is dead .please try to charge it several minutes and try to turn on with charger plugged in.
if it solves problem you can check the battery status via diagnosing software.
regards,
nuwan.
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
2answers
I just bought my smartbook today. When I plugged it in to charge... the red light comes on indicating that it is charging for no longer than a couple of minutes before turning off. Also, when I try to...
I would not attempt any repairs, return this if it is under warranty, there is a fault with the battery, the charger, or the charging/power circuit
2helpful
I dont know how to charge my GARMIN nuvi 1200 with the usb cable
There are 3 ways to charge your garmin nuvi 1200 as follows;
  1. Connect your satnav to a computer with the mini USB cable. Plug the narrow end into the satnav, where the power cable goes, and the other end into the USB port of your computer. Both computer and satnav must be turned on. It will take about 8 hours to charge like this.
  2. Connect your satnav to your car charger and plug the charger into the cigarette lighter socket of your car. It will take about 4 hours to charge.
  3. You can get an optional mains charger which also takes 4 hours to charge the satnav.
May 23, 2011 • GPS
1helpful
How will you charge a gps nuvii garmin 1450 using computer?
To charge a garmin nuvi gps with your computer you connect your satnav to the computer's usb port using a mini USB lead. Turn on the computer and the satnav and the satnav will begin to charge. It will take approx 8 hours to charge compared to 4 using a car charger or mains charger.
Feb 05, 2011 • GPS
1helpful
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
2helpful
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
Oct 29, 2010 • Cameras
1helpful
WILL CAMERA CHARGE CONNECTED THROUGH USB INTO THE COMPUTER OR IS THE DOCK FOR THE CHARGER THE ONLY WAY
The S51c will NOT charge through the USB port. The camera does not include any charging circuitry, which is why it comes with a separate battery charger. Connecting the USB port only drains the battery faster, as the camera now has to communicate with the computer (even if only to say it has nothing to say).
The included charger isn't the only way... you can get third-party chargers that will let you charge, for example, from a car cigarette lighter. But you do need to use a charger, not the USB port.
7helpful
3answers
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
