Most Wireless Clients Cards (Laptop/computer) can
be configured by a Manufacturer Wireless Utility that comes with the card, or
Windows Zero Configuration (WZC)
It is important that the Wireless should
be managed only with one application.
You can use the Original Utility, or WZC. When one
is used the other has to be Off (Not loaded into memory and not maintained
active Windows service).
Disabling the Manufacturer Wireless Utility should be explained in the Wireless
Cards document.
The following describes how to
Check, and switch WZC On. The same principle applies in case you need to switch
it Off, choose the Off/Stop options while you are at the menus (the
same method can be used to configure other services too).
1. Click Start and Run
2. Type into the Run box "services.msc" (without the quotation).
3. Scroll down and look for the service Wireless Zero Configuration
Double Click on the Service,
Screen Shot of the services
4. Make sure that it is Started and that the startup type is set to automatic.
If the Service did not Started, or and is Not set to Automatic.
To Start the Service click on the Start
button.
To set the service to automatic, click on
the down arrow and change it to Automatic.
No Windows Zero Configuration Service at all.
Use Windows regedit, drill down.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WZCSVC
Add a DWORD entry named "Start" and value "2".
Note, if you are Not familiar with
regedit do not try to use it without knowledgeable support.
31 questions posted
43 Questions
5 Questions
2 Questions
3 Questions
