Not turning on, the power switch is lighting green, after a wile from turning on the unit it gives that the lamp is defective i replaced the lamp but still same problem. pls advise. Thanks
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Did you try fit the right resoltion and frequency?
then do a factory reset.
it worked with mine!
This seems to be a protection device that perhaps need resetting Does your manual give any help here? Alternative contact Dell or if you can spot it the Projector maker[Dell don't make projectors-] so it is a re badged main make. Or look on the web for a projector that has the same appearance to yours and check out the make.
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Thanks Jackboy can you help me find the maker of this item
Greetings. I have the same problem, it all started when one day I turned off the projector and unplugged immediately after I disconnected it, so I didn't let it cool off. So I turned on again and got the "lamp" light coming on, I assumed I burned out the lamp. I bought new lamp, replaced it, no signs of life. Thanks for any help anyone can provide.
Same problem here. Replaced the lamp, no effect. Took the whole thing apart last night to see if there was something obvious. Nada. None of the fans come on at all when I turn the unit on so it seems like a power supply problem to me but I would like to hear what a normal 2300MP works like since I got this one already dead. There are two fans inside, one is a regular fan for general cooling of the unit and the other is a blower in the lamp area. Can anyone tell me if these turn on immediately when the unit is turned on or if they wait for the unit to heat up before turning on? What I would like to find is a 2300 that someone is selling cheap because the lamp is dead so I can have a working one to compare to. Or a service manual or schematic would help too!
automitic black screen after that once restart it will again start
I have the same problem. My company bought three of them. Two have the problem and the third one is OK. So I exchanged differents partsa , and I discovered that the problem came of the mainboard. But I don't know if the problem is a problem of hard or a technical problem.
Hello, My projector is acting up when i try to turn it on the temp and linght led start flasing and nothing happens. when i called dell got some one who i could barely understand and it was of no help. any idea of what could be happening
thank
