Weber Chill 05-161 Beverage Cooler Logo
Anonymous Posted on Jul 03, 2013
Overheating We had this unit for several years. Has worked well. Recently it seems to be overheating , exterior side wall gets very warm. It is still cooling, but does not seem to cycle off. Does this sound repairable ?
  • John Tripp
    John Tripp Jul 04, 2013
    If the coller does not have a fan for condenser then for some reason the cooler is working too hard could be that the door is not closing. On many coolers it is normal for the exterior surface to heat up because that is how it transfers heat from the inside to the outside. Thanks John T
John Tripp
Level 3:
  • Weber Master 4,656 Answers
  • Posted on Jul 04, 2013
John Tripp
Weber Master
Level 3:
Answers
4656
Questions
Helped
1679270
Points
14883
Usually that is a sign that there is a blockage to the condenser fan below the cooler. See if the condenser is dirty, or something blocking the flow of hot air from the condenser fan area. Check
the condenser fan motor to insure it is healthy and running strong. Recommend cleaning condenser to allow air to circulate the area freely. If fan is slow, stopping or not running I recommend replacing the fan motor. Sea Breeze
The wall seperating the fridge and freezer is overheating. The face of the wall is about 139 degrees F. The rest of the the fridge is just fine.
Hi there
There is a trace heater in the frame of the unit to prevent ice build up, this seems a little warm but I don;t think its a problem. Sometimes in manufacture the heater is a bit closer to the frame than it needs to be.
If there is no discoloration of the frame then I think it is nothing to worry about
Regards
Gordon
SBD21VE Side-by-Side - water dispenser line seems to be freezing. Water is still getting to the ice maker, as ice is still being made. When I recently had the fridge unplugged for a thorough cleaning,...
COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
The refrigerator is dead 3 years old and I have I woke up to a dead box
Bottom freezer working okay. Refrig not cooling. No ice in door. Took cover off door and seems to be operating properly. Is there an internal fan that blows cold air up from freezer?
Whirlpool side by side, model ED25RFXFW01, is in garage - garage is cold this time of year and freezer/fridge warms up inside - is a garge kit available for this model?
Fridge Freezer errors COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
I have a GE Profile Arctica side-by fridge that previously worked great, however we moved and now won't cool. Maybe important: to fit in a pickup truck the fridge was transported on its side for about...
COOLING
Electrical
PARTS
1helpful
Finding a suitable thru the wall air conditioner
Not exactly....if you can half or more of the side vent exsposed then you will be okay...I like the side vent models because they are less prone to recycling the air...they either pull in the side and expell out the back or visa versa...
On the total back models all the air is just pulling and pushed out the back and they are prone to overheating in some wind conditions...the air just recycles...
Of course the main problem is that most people fail to keep their unit cleaned properly and that causes the overheating...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
1helpful
2answers
Ge mini fridge seems to be overheating
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Top Weber Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Weber Refrigerator Expert? Answer questions, earn points and help others
