20 Most Recent LG LSC26905 Side by Side Refrigerator Questions & Answers
3answers
Hello, My LG refrigerator has a ticking sound
If freezer performance goes down you might want to check out the defrost timer/heater.
9/10/2017 1:26:09 PM • LG LSC26905 Side... • Answered on Sep 10, 2017
Our LG side-by-side, model # LSC26905, suddenly
Switch off completely and leave for 30 seconds. switch back on and cooling should start in under 5 minutes. If not, check inline fuse and output to compressor.
5/4/2017 5:30:15 PM • LG LSC26905 Side... • Answered on May 04, 2017
2answers
My ice tray does not go up fully allowing water to pour into the ice bucket as well as down the inside of the fridge. What can I do?
There is usually an on off switch inside the ice compartment but at times there is also metal bar that needs to be moved from top to bottom or vice versa. This controls automatic ice making and delivery.
9/5/2016 10:21:15 PM • LG LSC26905 Side... • Answered on Sep 05, 2016
0answers
Leak in back next to bottom the blue connector
Can you please be more specific and if possible add a picture?
8/5/2013 12:18:34 AM • LG LSC26905 Side... • Answered on Aug 05, 2013
0answers
2answers
How do you unlock a keypad on an lg refridgerator?
I assume that you means the keypad that controls the different modes for the water/ice dispenser. Press the far right key
10/12/2011 2:52:01 AM • LG LSC26905 Side... • Answered on Oct 12, 2011
Water running down front of refrigerator and
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
9/27/2011 7:47:21 PM • LG LSC26905 Side... • Answered on Sep 27, 2011
LG LSC26905 makes ice, but
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
9/17/2011 7:24:08 PM • LG LSC26905 Side... • Answered on Sep 17, 2011
The refrigerator is dead 3 years old and I have I
COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently
1/27/2011 3:48:01 PM • LG LSC26905 Side... • Answered on Jan 27, 2011
LG LSC26905 Side by Side Refrigerator Logo
42 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
icemaker not producing ice water not
  • Refrigerators
