I just got this washer/dryer combo. First run went fine, went to do a second load and now water keeps pouring out of the detergent dispenser every time I turn it on. Yes, I have checked and the door is as closed as I can get it to close. I've tried and retried. Help!
Use low sudsing soap powder
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
mine is a HAIER HW-C1460TVEME-U. i have the same problem. Loads of water everywhere.engineer hasnt a clue and have now written off my machine and its only just uner 3 months old!!!!
