Konica Minolta magicolor 2430 DL Laser Printer Logo
Posted on Aug 23, 2007
Yellow toner empty
Is there any way to bypass the lockout of the yellow toner empty so I can at least print black & white text till my yellow toner arives? Thanking you in advance, Bill
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 23, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3256
Points
16
You will need to use the menu on the printer itself to change a setting Press "Menu Select" button to get the menu function Use the right arrow twice to select "Engine", then press the down arrow to the "Replace Toner" menu Press the right arrow for the "Toner Empty" menu Press the down arrow to get the Toner Empty settings Press the right arrow to change the Toner Empty setting to "Continue" Press the "Menu Select" button to confirm the setting. You should be able to print, you just won't have any yellow toner. When you get your toner cartridge, follow these instructions to reset the 'Toner Empty' setting to Stop so you will know when a toner is out.
I can't print in black and white though I have black toner
Hi, when the printer finished warming up. it will prompt Toner Empty - Stop, use the arrow key changed to continue and you can start printing. remember you must always do that whenever this msg appears.
B&W Printing w/o Yellow Toner
yes, on most printers. just have to set preference to black and white in printer control panel
My Samsung CLX-3180 printer is only printing in Black and white
The printer might be out of one of the colors of toner. Most color laser printers will revert to black and white when either the cyan, magenta, or yellow toners run out. Check to see if any are empty or near empty. Also check the settings on the printer and your computer to make sure that it is set to print in color.
1helpful
Need to use the printer machine in black and white as missing yellow toner waiting for it but machine is blocked and need urgently to print docs. Pls help me
Unfortunatley most printers will not allow you to print if one of the colours are missing or empty.and so you will need the yellow toner to be replaced before you can print. there is a way that sometimes works and that is to remove the toner cartrige and give it a good shake this evenly distributes the toner inside and sometimes make the printer think it has enough toner and allows you to print. As I said this only works sometimes and is not a perfect solution
7helpful
2answers
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
1helpful
3answers
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Printing black/white when color toners are low
Try taking the color toner containers out of the printer and shaking them a bit. Put them back on and try again. This could confuse the sensors into believing that you still have some toner left.
Good luck
2answers
Printing in grayscale
yes u can use it with black and white
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
