The pump was run hot for a while now it just clicks. Thinking swapping the thermal switch. Ideas?
SOURCE: new 1.5 hp super pump hayward, blows circuit when
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
SOURCE: hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
SOURCE: Haywards Super Pump Tick tack sound
The bearings and brushes are going. It could run like that for up to 5 years...
Some people specialize in fixing these, not too many though. I would replace the motor instead of throwing good money after bad.
SOURCE: My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
SOURCE: Clicking noise in new Hayward Super Pump
make sure the pump motor is set for 115 volts, it soumds like you have the motor set at the factory 230 v setting and are trying to run it on 115 v look on the motor label it will show you how to set the motor up for 115 v (if the breaker is wide 230 if its skinny like the ones that control your lights its 115v ..if you have ran it for awhile like this you may want to search your area for your local pool pump motor repair guy w/ free testing, because you may have damaged the start capacitor about 20.00 or less fix.if not this can come back to haunt you later,,jay
