Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
