The pressure guage goes up to about 50 lbs. and doesn't gain any more pressure. The pump continues to run (the motor runs constantly as long as it is turned on). This is just with the compressor turned on to pressurize the tank, with no tools or hoses attatched. I replaced the piston and sleave and the head seals. The piston and sleave were in very bad condition in spite of the compressor not being very old (about 3 years, only used occasionally). Before the repair the guage only went up to about 40 lbs. with the pump running constantly.
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER.
Have you got the compressor hooked directly to a wall outlet (i.e. no extension cord?)
Also, no air leaks anywhere in the system?
