D-Link AirPlus DI-524 Wireless Router Logo
Posted on Mar 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i upgrade my firmware on my dlink dl-524?
How do i upgrade my firmware on my dl-524?
Anonymous
Level 2:
  • Expert 33 Answers
  • Posted on Mar 17, 2009
Anonymous
Expert
Level 2:
Answers
33
Questions
0
Helped
62135
Points
141
Go to the following website to download the firmware update for the DL-524. This will save the firmware update to your harddrive:
http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware
1. Open the web browser
2. Type in the IP address of the DL-524 router.
3. Type admin in the user name field
4. Type the password you set on this device
5. Click on the Tools tab
6. Click the browse button and locate the firmware file you downloaded and saved to your hard drive.
7. Click the apply button to complete the firmware upgrade.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13846
Points
Thanks for your help it works for me
regards,
Yogesh Chavan
How to install dl 524 wireless router
Hi There,
Please follow the below link to Install and setup the DL 524 wireless router.
Link :
http://www.shoalhaven.net.au/sis/setup/dlink.pdf
Enjoy !!!!
How do I change my DL-524 from unsecure to secure connection?
Enable WAP/WEP encryption, in the routers setup. Check your manual or DL the one below. ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Bobcat DI-524 Status light does not come on.
I think the firmware get corrupted.
You will need to download and restore a new firmware.
Here are the links
ftp://files.dlink.com.au/products/DI-524/
ok
try this
Any other help you are most welcome.
Regards
Uttam
Wireless drops off after 30 minutes, comes back with reset, then drops off in 25 minutes, and so on. wired internet ok.
This is a problem with the firmware of your router since the wired part is working fine, to correct one you need to do a firmware upgrade on the router you can get the latest firmware from Dlink web site.........
How do i connect dlink dl-524 to pc without i want to set up lapt
You should be able to download the software/driver package as well as manual from the DLink website. Just click on the Support link and lookup the model # of your router. You will need to know which operating system you are running in order to download the correct package. Once downloaded you can install by following the onscreen directions. Hope this helps.
2helpful
2answers
My DLink DI 524 wireless quit on me...ethernet is still operating
You stated "The SSID is not being broadcasted either." Turn on your SSID broadcast so your computer can see the network and reconnect back to it.
Why is my modem not recognised by vista ???
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
1helpful
2answers
Disc missing
Hello, Click this link and search model number for software & driver. Hope this helps.
http://support.dlink.com/chooseCountry.asp
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
