This is usually caused by a failed front control module as this unit controls the lighting on the vehicle!
airbag reset tool
SOURCE: low beam does not work on passenger side only
It could be a realy..
Find the relay location in your manual..
Have a great day !
SOURCE: My headlights alternate, the daytime light works
Remove the front control module. (in front of the fuse panel under the hood) There are pins in there that get corroded. Give them a slight twist. this will increasetheir connection when you put the module back in. I had the same issue. took about ten minutes to fix. Dealer wanted 4 to 6 hundred for a new module.
SOURCE: Passenger side low beam and same side front and
if your lexus headlights do not work and your bulbs are fine it is most definately due to the xenon computer that makes them work...it costs over 1,000 dollars not to mention the costly labor...got mine on ebay for 82.00 and paid a day laboror 50 bucks total of 132.00 to fix an otherwise costly problem.,.
SOURCE: Audi A4 2002 Low beams & Right front turn signal stopped working
but on 2002 A4, F20 and F21 are empty! Does anyone has an idea where the headlight fuses located?
[Information] For a 2002 Toyota Camry, the Daytime
Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to
the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test
configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness
when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not
burned out. If one burns out, there is a fair chance that the other would have burned
out at the same time. Replace as necessary.
In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function
Switch on Turn Signals in "DRL" position, headlight switch off
(repeating what the manual says -- it should be obvious that in the
"DRL" position, the headlight switch should be off / do not have the
switch positioned to "High Beam"), and the Parking Brake
"off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box.
there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3).
Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues
could be that the Multi-function Switch is broken or a connection / wire is
broken. [Beyond the scope of this
process.]
My problem was that the test configuration did not have
the engine running and parking brake off - Step 1. Problem solved with much
thought, repetitive tests on the vehicle and going back to the basics -- what
does the Owner's Manual say and where are the applicable fuses and relays
located?
